TGLC's PerfX Color Recipe
jardo
Has anyone used this product? Any thoughts, opinions, and suggestions on it. I am looking to get the best CMYK recipe to match a spot color, lab value, or Pantone color, assuming I have a good working color profile set. Thumbs up or thumbs down?
I use it on an every day basis on profiles for flexo presses and it works fine. I use the whole PerfX line, I am not sure the Color Recipe can be bought as a stand alone. Check it out.
Hi jardo,
check these 2 threads:
- jitterbug's Pantone Matching for Idiots - here some tools and approaches get mentioned to get CMYK from Pantones
- kaiserwilhelm's Automated GCR then goes into device-link reseparation, which would likely optimize a non-optimal CMYK recipe version for your spot tint. So if you use e.g. a UCR-style CMYK recipe for a spot on an otherwise GCR heavy page, it might not balance right. Which is likely what you mean with "best CMYK recipe".
You might read a few other things there as well, which could help you in your quest
Juergen
Hey Jurgen
Hey Jurgen
Thanks for the response. I hope you rememeber my screen name and can pare it up with a face. How is life?
Thanks, I will check out these links.
sure - jardoman ;-)
Will be at PIA/GATF color management conference in Phoenix - if you're there you can refresh your own memory of my face (otherwise you know how to contact me)
