Tool to measure paper thickness?
Hadrian
I know this is a rookie question but what tool do I buy to measure the thickness of paper (in points)?
I've noticed that several stocks of paper may have a different a cover weight but the thickness appears the same. For example I bought a 172lb cover stock and a 220lb stock but they both appear to be around 24 point thick; is this possible?
you will be looking for basic micrometer. And its very possible that 2 different papers of the same thickness weigh, feel, fold, and run differently.
get something small and handy like this
It's usually measured in 1000th's of a mm. (1 micron = 0.001 mm)
I prefer to measure 5 (for example) sheets at a time and then divide my total measurement by 5 to get a more accurate reading.
  • Like
Reactions: EEM
Oh, and yes, it's possible...
Thickness is not really related to weight: a thick piece of wood might weigh less than a thinner piece of steel, for example.
Thickness is not really related to 'stiffness' either: a thin piece of steel is stiffer (more rigid) than a thick piece of foam.
I know we're talking about paper here, but the examples illustrate the point.
