jwheeler
Care to expand on what you mean? To whom and which scenario are you referring to?if you think you can run those volumes monthly you are dreaming
350k A4 @ 100ppm = 58 hours work / 20 days = 2.9 hours per day. Most shops are active 8-9 or more hours per day and most work more than 20 days per month, leaving plenty of inactivity time, a couple of mornings for tech visits, etc. Looks reasonable to me.if you think you can run those volumes monthly you are dreaming
if you think you can run those volumes on the machines that were listed you are dreamingCare to expand on what you mean? To whom and which scenario are you referring to?
European specs are quoted in ISO216 paper sizes, US specs will be quoted in US sizes. Certainly this side of the pond, printer speeds and model numbers which include the speed as part of the numbering convention, are based on A4 size, irrespective that A4 is not a production size.and to not uk the person inquiring isnt going to run A4 and no printer runs A4
all printers run 12x18 and 13x19 US size
The OP said he printed 350,000 A3/SRA3 per month, not 350,000 A4. That's why he's trying to correct you. Nothing to do with your math, it's just that whatever your math is based on is not quite as relevant.European specs are quoted in ISO216 paper sizes, US specs will be quoted in US sizes. Certainly this side of the pond, printer speeds and model numbers which include the speed as part of the numbering convention, are based on A4 size, irrespective that A4 is not a production size.
My math still stands. A machine with a monthly recommended volume of 350k A4 will loosely equate to half that at A3 / SRA3 and guess what... the printing time will be similar!
My 350k was in response to Jacob's post showing the Xerox 4100 with a rating of 350k A4 a month, which the other guy suggested was not realistic.The OP said he printed 350,000 A3/SRA3 per month, not 350,000 A4. That's why he's trying to correct you. Nothing to do with your math, it's just that whatever your math is based on is not quite as relevant.
absolutely - the OP will defo need at least two machines for redundancy and the ability to be printing two jobs concurrently - on his other post (below) he has indicative volumes of between 40 and 75 orders per day of 500-1000 flyers. At the low end and if they were all simplex, for A5 4-up, that's 5,000 SRA3 sheets across 40 sorts. I would recommend two machines of the same breed, using the same consumables and parts. In the quick turnaround flyers business, you can't be a one machine operation and down for a day...Agree with pippip that if you're up against the machine's limits you might as well diversify a bit and get a second machine, especially if you are down for a few days awaiting parts or on a weekend with a big job and your machine goes down, it could really make a difference.
We serve over 200-300 customers per day for large format print, as the most other product asked for is flyers and leaflets by our existing customers, we think its a good idea to make more revenue from each order.
We believe 20-25% customers will happily add short runs of 500-1000 A5 flyers to their orders, as an average, but also anticipate larger orders as we serve alot of restaurants and takeaways.
