What is the specification for viewing conditions?
A question for you. What is the specification or standard that applies to viewing booths at the press.
I think it's "ISO 3664:2009*Graphic technology and photography -- Viewing conditions" but from its description I'm not sure. ($130 seems a bit expensive to find out it's not the right info)
thanks for any help - gordo
Yep. That would be it. Defining viewing condition requirements, illuminant, CRI, metamerism index, surround, uniformity, etc.
Thanks - a vendor responded to me and said that that document is more directed towards engineers rather than the average printer. In fact, every bit of info that I can find seems complex enough to stun a horse.
Just look at this entry on wikipedia as an example:
h t t p://en.wikipedia.org/wiki/Standard_illuminant#Illuminant_series_D
Very frustrating.
best, gordon p
Very frustrating.
best, gordon p
Yikes. We'll, the vendor is correct in that its geared more towards engineers/manufacturers, but its not quite as imposing as the example you provided here, and it can be a useful reference for an average printer. Is there something in particular your looking to get out of it?
I was asked this question and didn't want to respond without checking my facts. So I started rummaging around the interweb and soon discovered that the info - let alone practical easy to understand info - was pretty near impossible to find. You'd think this kind of basic info would be easy to get.
I do have some questions.
1) How do you measure Lux/Foot candles? Can you use a photography light meter?
2) How is reflectance measured? I.e. For surround it says "neutral surround with luminous reflectance of between 10% and 60%. What does that mean? How is it measured and with what instrument?
3) Chromaticity for the lamp for D65 is u'=0.198, v'=0.468 and for D50 it's u'/10 =.2102, v'/10 = .4889 . What the heck does that mean? How would you measure your lamps to confirm that they're in spec?
best, gordon p
Yep, you can use a light meter. Can also measure with an i1Pro spectro and i1Share or Babel Color CT&A.
Not sure as this isn't specified outright. Maybe a gloss meter or some sort of reflectance photometer perhaps? Many designing their own surrounds use a musell N8 or N7 gray paint.
These are the u', v' chromaticity coordinates in the CIE 1976 Uniform Chromaticity Scale Diagram (along the plankian locus). Although the D50 spectral distribution curve is the "target", the chromaticity is defined with a radius of acceptability within 0,005.
Short answer: you truly can't, unless you have a spectroradiometer that can measure from say 300-780 nm.
more practical answer: Using a light meter to confirm both color temperature and u', v' coordinates. better yet, use an i1Pro with Babel color CT&A Spectral tools. The device isn't capable of measuring far enough into uv, or ir, but can be certainly be useful. See screenshot.
Fiat Lux
Fiat Lux
Gentlemen,
A little "en-LIGHT-enment " !!!! a PDF hopefully of interest and value
Regards, Alois
  • viewing conditions # 1215.pdf
  • viewing conditions # 2216.pdf
  • viewing conditions # 3217.pdf
Fiat Lux part 2
Fiat Lux part 2
Enlightenment --- part 3 of Fiat Lux later
  • viewing conditions # 4218.pdf
  • viewing conditions # 5219.pdf
Fiat Lux
Fiat Lux
Part 3 the last part --- but first,
"Color is life, for a world without color seems dead. As a flame produces light, light produces color. As intonation lends color to the spoken word, color realized sound to form. Harmony implies balance, symmetry of forces. Colors are primodial ideas, the children of light"
Johannes Itten, from The Art of Color
Regards, Alois
  • viewing conditions # 6220.pdf
  • viewing conditions # 7221.pdf
Just to add to that...
Here are two documents ...
The ASTM 01729-96 Viewing Standard specifies the conditions for the critical visual color
appraisal for color matching.
ISO 3664:2000 - viewing standard for graphic arts
  • ASTM D1729-96 Viewing Standard.pdf
  • ISO_3664.pdf
Eric Dalton's article "New Lighting Standard" about ISO 3664:2009 was published by Printing Industries of America: The Magazine, August 8, 2009 (Copyright 2009 by the Printing Industries of America, Home | Printing Industries of America - Printing.org), and reprinted with permission in the Seybold Report Volume 9, Number 20. Octiober 26, 2009.
Eric Dalton is Vice President, JUST Normlicht Inc.
That article is worth reading.
regards,
Barry
Fogra certification for Just Normlicht
The attached press release just came in.......
"JUST NORMLICHT standardized lighting solutions have been certified by FOGRA based on the
ISO 3664:2000 P1 and P2 criteria."
regards, Barry
  • Just News 01_2010-FograCERT_doc.pdf
