When should I change the ink?
DMP
Hello everyone,
I hope this is not a stupid question but I do not want to damage my printer! I have an Epson Stylus Pro 7800 and it is giving me a low in warning. One of the cartridges is low through normal use that is fine but should I replace it now? The reason I am asking is because it still has ink in it. I feat that if it runs out I may get air in the lines or have a problem because I did not change it when it told me to. What is the worst that can happen if I use it until it runs out?
Also while I am here, I have some inks dated 2008, 2010 and 2012. Are they ok to use or should I bin then? The whole system is Ultra Chrome K3 ink.
Thank you very much in advance for any help,
DMP
AngusPady
DMP, run the printer until the ink is 100% used. You will get a message when the ink is out and replace then. No need to replace prior and nothing bad will happen
DMP
Thank you for your help. I will do that and replace when the printer tells me to. I worry because I have already ruined an Epson 9800, it had a print head clog and ended up being only good for spares or repair!
What's In Your Warehouse
What's In Your Warehouse? Are You Sure?
In an average week you process what, 50 jobs?100? 150? 200? Let’s say about half of each job hits the mail or goes out to the customer. The rest goes to shelves in your warehouse so it’s ready when the client needs it. Juggling all this—and making money from it— requires Link to Article
