IMG-1031 hosted at ImgBB Here is the picture.Im constantly getting the same error.77-320 alingment shifter fail.I cleaned all of the sensors,tried everything i could find on the internet.Got the same result.I cant access my diagnostics because my license ended last month .
Could you send me a pic of where its located?Did you clean the sensor under the 2nd BTB?
Cant use my diagnostics it ran out last month.Hi,
This is which if found online "Check the front and rear aligner sensors for contamination. Run the DC330 tests shown in 77-320 RAP to check the aligner motor moving front to rear and both sensors. ." although I have to admit I never have/had a xerox.
I have the Iridesse but I would assume the 1000i would be the same. Just pull out the 2nd BTB and below the alignment rollers towards the outboard side of the machine, you will see a sensor there that had a cam that passes through it. There is also a cam sensor on the top alignment roller on the inboard side to transport tray. I am assuming you probably cleaned that one. I am also assuming that did the reset routine for that error as well.Could you send me a pic of where its located?
Already cleaned those .Without sucess thoI have the Iridesse but I would assume the 1000i would be the same. Just pull out the 2nd BTB and below the alignment rollers towards the outboard side of the machine, you will see a sensor there that had a cam that passes through it. There is also a cam sensor on the top alignment roller on the inboard side to transport tray. I am assuming you probably cleaned that one. I am also assuming that did the reset routine for that error as well.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
