jotterpinky
We are currently having trouble with our Xerox 700 DCP getting it to register color to color accurately. For instance the job we just finished was a color build black (20 C, 20 M, 20 Y, 100 K) with knockout white text. After running several sheets of 12pt C2S stock the color goes in and out of register across the sheet. We are running 12x18 sheets and the color comes out of register about halfway across the sheet. Its most noticeable when the Magenta is out of register as the text appears pink. However looking through the stack there are also a number of sheets where the cyan or yellow is out. Looking under a loupe its at least 2-3 dots off.
Anyone have any idea what we could do to fix this? The stock is within the machine's 300 gsm max coming in at 267gsm but it is rather stiff. I've only noticed the registration problem when running heavy stock. Is there something I can check that might be causing this problem or am going to be relegated to running only lighter weight stock?
