Xerox Versant 80 rip
ad41061
I have an Xerox Versant 80 with the Xerox ex80 print server firey which is not working and can't seem to find the fault, is there any way to print from another computer without a Firey server?
Thank you for you help
If the same as KM, you can install a driver on your server or PC and print direct to the engine, instead of going via the RIP
The print server keeps turning off, so I thought it might be overheating so I put new past on the cpu, same problem, thought it might be a harddrive issue and disconnected the harddrive and let the computer boot ang again it would switch off after around 15min, thought it was a ram problem but I dont think so, not the powersupply swaped out that as well , no joy switching of again, so back to cpu, I have ordered a new cpu
There is no builtin print controller into V80 so you must use Fiery for print.
