Avantra 30 Error 64
suezew
Has anyone had any luck clearing an Error code 64 - Flapper Jam. I've followed the book and it's not working.
Any suggestions?
Flapper jam
Flapper jam
If you have "Avdiag"- very easy to check flapper sensor and motor also.
May be you chech belt in the sensor assy.
You can move the Flapper through the Display as well. look at the flapper see if it moves back and forth freely.Look if it is Jammed. Mechanical?
Wiring, sensor, flag and Motor. Need to be tested.or you just may have alignment problem.
Contact me I can help you.
Contact me.
[email protected]
Home
