Avantra 30 problem
LUIS AVILA
I had an AV30 on service, with a DEC board failed to boot. I got an used DEC board, now the machine boots ok, but when I try to film error 41 appears (bridge not in possition) but I´m sure bridge is in possition very lowered . Then I run the AVDIAG to check the sensors, but in the first screen on the AVDIAG programs appears the Software Revisions of AV30 and shows BRIDGE/OLP (OLP FlashROM) : n/a. I am thinking this is the problem, do you can help me how to resolve it?
Luis, your new but used DEC was NOT configured for Bridg/OLP in use! Probably that board was installed before in Avantra 25 with off-line processor and TakeUp cassette.
But you are lucky, having AVDIAG!
Go to the Avantra Configutarion Menu (default password is four zeroes - 0000) and declare Bridge board INSTALLED!
And you have to copy all DEC parameters from your old board to new or to type them manually if you have a paper with those parameters.
That is very important, especially for parameter BOL - Beginning of Line i.e. - othervise your image can be cropped on top or bottom (if you use maximum height size of job 635mm/ 25")
Sorry I am new using AVDIAG ? How I declare Bridge board Installed ?
I sent my diskette to the people who sold me the DEC to they restore the parameters of the new DEC, but they say is not very important.... :(
Now I have to adjust BOL (I know how) what else do I have to adjust? if I don´t get my diskette back.
thank you very much for your help
Best Regards,
Luis
AVDIAG Main Menu -> ALIGN -> Engine Configuration
Bridge-Up Sensor should be disabled (because it's for 44 version)
Bridge DfLight Mode -Disabled
Bridge/Buffer Board - Installed
Some parameters are original/unique for EVERY Avantra30 (focus, start point for polariser, carriage home offset... and a few more) - that's why I told you to copy old params in a new DEC board.
That's all I can tell you here and I told you too much! :)
If you want more - you have to call service... and pay for it.
BTW: AvDiag is a Service programm and was created not for users because some hidden tricks and steps sequence.
Some wrong actions or mistakes can be Fatal.
