Tony Blanco
Banned
Hi all.
This Avantra is presenting the following problem. The size of the image on vertical direction is 2 mm bigger than normal. After printing a 100 cms ruler at horizontal and vertical directions, the horizontal ruler is good but the vertical one is 2mm bigger. I would like to know if there is a command or parameter that can correct this issue. On the other hand, if I print a vertical ruler at the left margin and other one in the middle of the film, both measure different, one is ½ mm bigger than the other.
Do someone has an idea?
Thanks in advance.
Tony Blanco
Thanks in advance.
Tony Blanco
