Canon 7000 Duplex problem
srspdy7390
On duplex prints there is always a discrepancy of .08" from one side to the other. Has anyone else encountered this and is there a (relatively) simple way to adjust this in the printer's settings?
Re: Canon 7000 Duplex problem
This has been our experience only when the paper is not cut to the same length as the paper you did your initial setup with.
There is a setting for each paper that will let you set the scale/zoom factor. Make sure what you are printing out is also the correct width and height as I have noticed that the thinner stocks have a tendency to stretch/shrink unevenly front and back.
In your Properties, under Finishing, there is a check box titled, "Image Shift". Check this box and then adjust the image shift in the direction you need it to go. Good Luck.
