I am assuming these are already stitched?
We have fed out of our stahl into a knife folder. Tends to run a little slower.
It's better to come out of the stitcher into the knife, faster production speeds.
Have also done this on the flat cover feeder of a stitcher, if you have one.
Greg
What is the quantity? ..... If this is a recurring project and you have a right angle unit that is used on the folder you can take a couple of rollers out and have a groove put in them and run stapled work through them.
Quantity is between 600 to 2600 for each of up to 25 to 30 jobs a month. They are recurring newsletters that we prepare for the US Mail. Putting a groove in the right angle unit of the folder seems like a pretty good idea. Do you have any trouble using the unit for "normal" folding after the grooves are cut?
Dan B
I was first thinking I could take the right angle unit from the folder and put it at the end of the saddle stitcher. I decided that would take too much jerry rigging. In the mean while, with some research I came upon a "Baum K20 Knife Folder" that is supposed to be able to be put on the end of the saddle stitcher.
I'm going to get more info on it. If anyone has one, please let me know what you think of it.
Dan B
ondemandbindery, I mentioned in an earlier post that have a Standard Horizon Stitchliner and a Duplo. The Duplo is a system 4000. The Stitchliner doesn't have a cover feeder. Covers are feed through the bins like the text sheets. The Duplo has a station in front of the bins where you can hand feed sets. We also have an MBO folder.
I'm still checking things out. 30K for the Baum seems a bit high. I'll shop around.
Thank you Craig for the info on the K20.
I have the stahl vfz52? same as baum. I use it on the stahl b20 usa to fold tricky small stuff. I use it offline to refold books to 5.5 x 8.5. i forget but I think use mine was like $12,000 and new was like $26,000
