iJetColor 1175 Pro general color experiences?
Make_It_So
Hi guys,
We have had this device for about a month or so now and the one thing we noticed is the kinda washed out looking colors. I attempted to match a Reflex order today and it was so far off we had to pull it and send it to one of our offset presses.
Is this common for this press to be a bit on the washed out side? I have played around with the different print options too like "Color Blast" and it was underwhelming.
Shawnd
What you are printing on can make a difference, I have had to use the special "Digi-M" envelopes to hit a certain color on my memjet.
MitchtheMitch
We've had our iJet 1175 for over a year and have absolutely loved it. What you have to realize is that the inkjet ink set will not be able to reproduce those really deep or bright Pantone colors, especially Reflex Blue. No CMYK device can match Reflex Blue. We have found that it matches (or at least is a sellable match) around 85% of our small press work
Make_It_So
Thank you. Nice to know. I will pass this along.
Craig
Make sure you are using Pantone C(coated) colors and not U(uncoated) in your files. Don't forget you can tweak the colors as well in the DFE. We print on normal everyday off the shelf envelopes, not the expensive Digi-M from Western. We print a lot of corporate colors and have never had any issues. We have roughly 3.5 million on our 1175P, so I'm thinking by now an issue would have popped up.
Make_It_So
The Printect Cockpit outputs PMS as CP colors. I just changed an order to C and it did make a difference but still needed quite a bit of adjustment. Of course I am dealing with a blue color (PANTONE 2945 C). It just can't get bright enough and looks washed out compared to the offset sample I am trying to match.
gregbatch
Indeed. My book has no such info. What book are you using? Thank you, sir.
Look for four dots in a square pattern below the color. That indicates that a reasonable match of the color IS ACHIEVABLE using CMYK. If those dots are not present, then you will not be able to match that color with CMYK.
gregbatch
I rarely used Pantone build numbers. Always had to adjust. I could almost always beat the bridge book. Also, try mixing 8XX flourescent colors into your primaries to make things pop.
