PhotoShop CS4 users can use device links already. I would be happy to build a SWOP v2 to ISO Coated device link. I just need to know a few parameters such as how much GCR, ink limit, how to deal with primaries and secondaries, etc.
Having said that, there is no practical way to "test" a device link at a customer location. The problem is that the device link is "software" that I can't set to expire in the 30 days or how ever long. So I would have to process the files with the desired device link. Which I a perfectly happy to do.
Here's how I do it:
1) Images only - I use PhotoShop CS4 to process the images with varying levels of GCR in the device links.
2) PDF's - I use Callas pdfToolbox Server to process the PDF's when applying the device links. I can apply the device links to images only, non-images only, everything, images that exceed a certain ink limit value, etc. Which is one of the nice things about pdfToolbox Server versus some color servers and in RIP modules. We can be very specific about how we handle the application device links. Most, if not all, color servers and in RIP modules that I know of other than Alwan ECO apply a static profile to the entire page. I can do that or I can apply different links to different objects on the same page.
So if you have a sample PDF and an idea of what you want in the device link I would be happy to build one and apply it to your job. It will probably take longer to send back and forth than it will to build and apply the device link.
