But if the banding has returned and you are sure the laser is good, then you did not do a fair test with the Fuji plates because your enviroment changed after the test. Have both Agfa and Fuji come in and try
Thead calibrations...processor changes...yikes. Been there done that.
We tried staccato awhile back, and we were not pleased with what we perceived as "graininess" in certain areas, so we decided it is not for us. However, Kodak believes staccato is even more susceptible to banding, and I agree.
I did consider this...240 ls at 2400 dpi...halftone cell is 10x10 (only 101 shades of gray!, so thank somebody for modern algorithms that make that not a factor)...essentially our 1% dot = 10 microns...P45s can only do ~25 microns (yet 1's and 2's do show on plate and press)...interesting...but our ls looks better than staccato in too many areas.
cannot rotate plate in Magnus...1030x800mm, but have rotated in processor...same results.
actually we did both with the processor (skew and 90). and this has been escalated. trying to avoid the downward spiral conversation...we're working closely with Kodak, albeit slowly.
Brand new, yet after 8 months, still not signed off on. Problem is banding (2+mm in width vertically across width of plates...visible in certain screens when printed). Presumably this is the width of a laser swath................
patience, PACH, please...still not resolved.
we too had "another" technician take a look. he hailed from Israel. better results, but not permanent. we ordered and finally just received a power conditioner today. in time we will know if it is the cure or not. i figure 1-4 weeks to be sure. i will post the results.
I have a Tech coming up today to work on the same problem. Our banding you can see on the plate itself, how did Kodak fix the laser related issue?
