ajdawson
After some advice if anyone can help to get a job plated which is desperate to be on press in next hour
- getting the following when trying to make a plate:
Fatal fault (02325) laser diode: possible coolant failure (WLP fault) (error code = 044302 error catergory = 7, Fatal, Device cannot recover)
Magnus has been completely shut down and restarted several times, different jobs have been tried but it is still giving the above error. The plate loads onto the drum no problem, then this error happens. The plate will unload from the drum when you tell the magnus to do so without having to do it manually. Also tried different sized plates (B3 rather than B2) and Thermal Direct plates, but same error.
Any ideas on what to try anyone???
