After a week and half of having the new drums installed only 2 flips.
We run 5 6501's 15 hours a day so I'd say they are a dramatic improvement so far.
You need an IGEN 4.
The one problem here is $40,000 x 5 is not equal to $650,000
And 65ppm x 5 = 325 which is greater then 110 ppm.
325 at only 8.5X11 at 20Lb paper. Heavier stock would be more like 22ppm X 5=110 ppm. Plus way better quality with the IGEN.
It's actually 33ppm. Please validate your reasoning behind thinking the IGEN prints better than a c6500. Other than you just think it does.
I can validate why the c6500 prints better than an IGEN. Due to an inherent design flaw
(colours are laid down in the wrong order DUH!) the IGEN cannot produce a rich black. Your turn.
Colors laid down the in the wrong order? What order would that be? Why do you think the Japanese boxes would be different?
When it comes to things being backwards, look at the out put trays on the 6500. The paper is fed from right to left and the finishing is on the left. That is how the Japanese read. Right to left. Americans read left to right, which is why the Xerox products imput goes left to right.
By the way, 350 gsm print capabilty with with coated or not at rated speed! Prints on the IGEN stay perfect from 1- 10,000. No slow down here.
You need an IGEN 4.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
