Offset trap size (Industry standard)
dgraves8rd
Stupid question: One of our salesreps is upset with the width of our traps. What is the industry standard for offset traps? I have done google searches and can not find anything.....
There are no stupid question - but there might be stupid answers :)
Trap amount depends on many factors, printing process, substrate, lpi, etc. The classic rule of thumb is to calculate from the line count of the halftone screen and be equal to half the diameter of a halftone dot.
For example, for a 133 lpi screen. Divide 133 into 1 inch to get the diameter of the dot. In this case 1 divided by 133 = .0075". Divide that by 2 to get the suggested trap diameter. In this case it would be .004". While an 85 lpi screen would end up with: 1 divided by 85 = 0.012 divided by 2 = 0.006" and so on.
best gordo
Yes, maybe you missed my post:
best gordo
If my math is still correct and I use the ancient term of 1/4 point trap that would be using gordos number .004 x 72 =.288. Is this correct thinking?
Errr, I hope your math class teacher is not reading this thread :)
Taking the 1/4 point trap idea:
72 points = 1 inch
so 1 point = 1 divided by 72 or:
0.013888888888888888
which rounds to:
0.014" = 1pt
so 1/4 point equals .014 x .25
which equals:
.0035
which rounds off to:
.004"
Which is one of the values already quoted for 133 lpi. Which may be where this notion came from - SWOPland back in the day.
So the 1/4 idea gives you a value that works, however it does not accommodate changes in lpi which the method I posted does.
best, gordo
best gordo
I do not agree that the trapping distance has anything to do with the screenruling, this is completely unrelated. Trapping is to disguise printing registration errors and this depends on the printing technique, press, substrate, temprature, humidity, ... but not the screenruling.
With a higher or lower screenruling there will not be a bigger or smaller registration error, hence...
For offset this will ususally be between 0.002 and 0.004" or between 0.05 and 0.1 mm.
For flexo this is quite a bit higher and can easily go up to 0.02" or 0.5 mm. or sometimes even higher.
Sheetfed
We use .003 for small presses
and
.006 for large format (64 - 81")
