The sheet in the left is blank not printed and the sheet in the rignt is printed it must be like the otherIf you simplex the print which side is it on?
I will have a margin of 2mm if i print 330x480 sheetDoes this background image bleed off all four sides or do you have a very small white margin on any of the sides?
Sorry if i don't underdtand your questionSince you didn't answer my question and haven't given us a lot of information I will just say if it is on the bottom side if a single sided print then look at the 2ndBTR. If it is the top side and all colors then make sure the ITB cleaner is replaced or cleaned out. Also check the condition of the fuser belt.
Place a call to xerox service. Machine have xerographics problems ( developer, drum, voltages )I have change the ibt cleaner not resolve tye problem
CMYK Processing Method is Full (Output GCR) is cheked but i don't have paper simulationjust to rule out that it's not a software issue... assuming you have a Fiery Command WS, could you check that the color settings are correct? - Please, check if the selected CMYK Processing Method is Full (Output GCR), and that the “Paper Simulation” checkbox is not activated.
Thank you for your answerI have a Versant 280 and have the same background toner on the print side. It’s only noticeable if you compare it to another sheet of unprinted stock that has a high white level of brightness. On coated stock it’s more noticeable, on uncoated stock it’s almost impossible to see unless you’re looking for it and even then it’s hard to find. The image that you posted does seem to be more evident but it’s difficult to tell for sure.
The toner that creates this background is smaller than the yellow security dots and can only be seen through a loupe. I don’t know for sure but the tech believes it’s caused from floating toner dust within the machine that gets fused to the sheet. If that’s the case, then it would be best to make sure all your filters are clean and to vacuum any toner deposits that have accumulated within the press. I think the floating toner explanation is a stretch but possible. It's not a Fiery issue, you'll get the same results from a copy off the glass.
I have some test files that were printed by Xerox on a Versant 180 and they too have the background. I never noticed this background when I was getting samples from vendors but sure enough when I pulled out the samples over a year later I could see it if I used a loupe. If this background image is the same as I’m describing then there is no fix, it’s a built in Xerox feature.
I have change all drumsI think the op's problem is different, looks like a 10% screen across the page.
Make a photocopy of something to eliminate the rip/software.
I'd change drums around to see if it alters, run a calibration too.
Hello, excuse me... could you tell me the yield toner of your versant 280 if you know. Appreciate! I'm interested in one of those printersI have a Versant 280 and have the same background toner on the print side. It’s only noticeable if you compare it to another sheet of unprinted stock that has a high white level of brightness. On coated stock it’s more noticeable, on uncoated stock it’s almost impossible to see unless you’re looking for it and even then it’s hard to find. The image that you posted does seem to be more evident but it’s difficult to tell for sure.
I am just now having this issue printing onto 80# Coated Cover and 100# Coated text. When I printed single-sided the backgrounding only shows up on the printed side. I discussed with the tech and they're going to try replacing the IBT first then then a Dev Housing.I have a Versant 280 and have the same background toner on the print side. It’s only noticeable if you compare it to another sheet of unprinted stock that has a high white level of brightness. On coated stock it’s more noticeable, on uncoated stock it’s almost impossible to see unless you’re looking for it and even then it’s hard to find. The image that you posted does seem to be more evident but it’s difficult to tell for sure.
The background has been there for me since it was installed. It’s light enough that customers don’t notice it, but it does change the brightness of coated paper. It becomes more evident when the black drum starts to reach the end of its life but replacing the drums never eliminates the toner background.I am just now having this issue printing onto 80# Coated Cover and 100# Coated text. When I printed single-sided the backgrounding only shows up on the printed side. I discussed with the tech and they're going to try replacing the IBT first then then a Dev Housing.
I sure hope toner isn't going to be a problem again. It took almost 2 years before I was running without loosing drums to bad batches of toner.We had a similar issue on Iridesse this time last year. Turns out there was a faulty batch of black toner which was causing a cast over the whole sheet. Perhaps you could ask service if this is something they have on record? I know there currently is a batch of bad toner in the UK/Ire for Versant 3100.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
