Hi Skumar,
Do you mean "smart-chip" saying RFID?
Did anybody try SmartChip Resetter? (lesnik - that's my idea for you)
Anyone used this supplier for refilling Xante toners yet? If so, how'd it go?
That is quite strange to hear. Basically Xante Illumina is an equal to OKI C9600 printer (actually being produced on the OKI factories). And as such, this machine has the same type of toner cartridges - separated from drums (the only difference is the RFID smart-chips and color keys positions). And toner cartridges are just plastic boxes with basically nothing inside apart of the toner itself and therefore there can't be any limiter that would define the maximum refill rate. I have a customer who have refilled OKI toners for more than 100 times so far. Not going to stop though... Note that drums are not that long lasting. Their life is "just" 30k pages, which can be easily extended up to 60-70k (if you use normal office paper but not a cardstock), but then you'll have to buy the new ones. Which is not a big deal again as each one is around 130-140$. By the way - OKI drums are cheaper that Xante ones! So make sure you are not paying more than you should!Be sure to take note that it says you should only refill the same cartridge 2-3 times.
Yes, OKI C9600/9650/9800/9850 drums are the same. The only difference is a color code keys. They sit in a different positions for OKI and for Xante. You can have a look at the picture of these keys:And OKI drums work in the Ilumina?
I have pointed that out: 30 000 pages as a quoted life working on 80gsm paper, can be extended up to 60-70 000 pages by replacing the fuse inside the drum cartridge.How much do those run?
Yes. If nothing done beforehand, the machine will display "Toner sensor Error or Image Drum not installed" error message. These pins define the precise position of the drums within the printer which is essential for the toner sensor performance: if the drum is not in the precise place, then toner sensor reflector will not be straight against the optical pair thus failing to reflect the light properly and causing the error above. The resolution for this problem is to remove the plastic items which concatenates with these pins from the machine for every drum. This will enable to use both Xante and OKI drums without limitations. And also Xerox Phaser 7400 drums since they are of the same type and manufacturer.Does having different positions of color code key affect anything when you put them in an Ilumina?
Angela007, What is it costing you to refill your cartridges. I tried the website that you provided and could not get it to work. How is the quality?
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
