Can anybody help with ArtPro's Step&Repeat function?
The fotocell i.e. cutting mark is partly outside the design. How should the Step&Repeat be made to have the fotocell set over the other repeat?
You need to set up the single unit with bleed, say 2.5mm for arguments sake. Then ensure the photocell is positioned at its correct repeat. Save the file.
Using interactive step & repeat select the single unit, set the number across and around and make sure you select the box marked keep bleed. Now when you step the job up the photocell will be in the position you require.
Or
You can set up the single unit with the photocell just under the start of the repeat, do not place a photocell at the bottom if using this method.
Step the design as above however on this occasion doe not select the keep bleed option, this should give you the same result.
