Thanks a lot for your helphello, this error is generally caused by the drum driver, if your machine model is between 2006 and 2008, the drum driver is hidden on the backplane. If it is a 2008 model and above, it has an extra drum driver and has a braking resistor. It is most likely the drum braking resistor.
Of course, when the error occurs is important.
If the image occurs after writing is finished, the error is most likely caused by the brake resistor.
if the error occurs during boot it may be caused by ACFB or ACDB-A-DC cards
If the error occurs at different times and in different locations, it may be caused by the encoder located behind the drum motor.
at best it could be caused by the drum belt
If an error occurs during plate loading, vct channels should be cleaned
Hello Samet,hello, this error is generally caused by the drum driver, if your machine model is between 2006 and 2008, the drum driver is hidden on the backplane. If it is a 2008 model and above, it has an extra drum driver and has a braking resistor. It is most likely the drum braking resistor.
Hello Hakimi,Thanks a lot for your help
We will try it
