I guess I limited my answer to patch or control strip measurement, which wasn't really the question. In addition to PressSign as mentioned, there's MeasureColor for actual press colorbar measurements with an i1. Or if your press is supported, you could possibly close the loop with InkZone
There is just one "problem" with i1 regarding density measurement. I1 does not have polarization filter so it basically measures "wrong" values (mostly too low)
Also, a spectrophotometer interpolates density values from spectral information which is different from how a densitometer measures density. That will certainly make the resulting values different.
Are there any manufacturers left that utilize traditional densitometric filters? Most densitometers are now "spectros" limited by licensing to report only densitimetric values, but often upgradable to full fledged spectros. That said, i found that the i1s I've used correlated quite well with older filter based densitometers.
