Xante Ilumina 502 Paper Thick Error
gtmo
Xante Ilumina 505 Error code 326
Have an old Xante Ilumina 502 which us mostly to numbering.
Getting Paper Thick Error - error code 326
just printing 11.5x14.5 envelopes which I have done in the past, other jobs print just fine.
Any help greatly appreciated!
If you are familiar with the printer, there is a sensor, it is in the middle of the paper track, right at the exit of registration rollers - paper thick sensor - make sure it is clean, also, there in a driver settings you may disable "media check", before everything, please doublecheck that you have a proper and matching settings in printer and the driver.
Thanks for the reply.
I have gone ahead and cleaned all out and got the correct drivers as you mentioned and is working now.
