P
pmkprog
Guest
I am trying to get my color set on a Xerox 700. I have an X-rite ES1000 and typically calibrate the Xerox internally and then use the calibrate through the Fiery Command Workstation to measure the swatches and apply that to the default profiles. My magenta is a running a little strong in the highlights and is a little weak in the around 75%. What is the best way with my limited tools to create a profile for the machine to hit a target I am aiming for? The other issue I have is that on some swatches of some material I am trying to print and color correct the 2% magenta is coming out as a pink in the proofs? The gradients I print look good though.
Any help would be greatly appreciated. All of the testing and targets are being printed on the same stock.
