SoggyWinter
We’re seeing image artifacts on 13x19 270gsm paper, both coated and uncoated. They are on the inboard (opposite operator) side and perpendicular to the paper path. About 155mm apart. 120gsm coated and uncoated 13x19 paper does NOT have the artifacts.
Other troubleshooting attempted for image artifact troubleshooting
-cleaned toner and fuser
-calibrated full width array
-swapped 2nd BTR with new in the box spare
-swapped fuser belt with new in the box spare
-swapped lower pressure roller with new in the box spare
-swapped IBT cleaner with new in the box spare
-swapped drum positions
-developer housings and developer have plenty of life left
-IBT belt is almost new
-cooling belts are new
Running a few hundred 13x19 impressions cleared the issue up for ~2000 impressions, but it came back a few hours later after the press had been idle.
We can rub the paper against the inside of the registration module and the paint or coating comes off the metal and onto the paper, which makes me think this may be an issue with metal coating particles getting scraped off the registration module and causing extra toner to get fused, but I may be grasping at straws...
