Introduce yourself!
Babu Paul
Babu Paul
Hi , I am Babu Paul , Support Engineer for Prepress/ Press in MiddleEast region working for 10 years.
Looking for solutions and answers on my queries from the experts.
Re: Introduce yourself!
Hi everybody,
i am working in Prepress industry since last 10 years; I started my carrier with Agfa-Gevaert Pakistan as a system support engineer in 1998, during my job in Agfa I was looked all technical and installation Issues of Agfa equipment such as Avantra 25/30/36/44, Select Set 5000/7000, Phoenix and Apogee Workflow Series3. In 2004 I joined Creo as a Manager Technical Support and looked Trendsetters, Platesetter 3244, Integris Proofing Solution, Prinergy EVO Workflow Solution and some other prepress software applications, now since 2006 I am working with Digital Imaging Solutions as a Manager Technical Support and looking support of both company products.
Hi, I've been in printing for 23 years. I started pulling a squeegee, changed jobs and went from floor boy to pressman for 10 years and moved into prepress.
We run Nexus to a Screen CTP.
Looking forward to learning more.
Gar
My name is Luis Nino
Hi, I've been working on pre-press for quite some time and the last 5 years I've been involved in developing web-projects using Pageflex. I work for Veritas-Solutions in Chicago as a pageflex programmer and also I do consulting on the side.
I'm new to this forum and wanted to introduce myself.
I've been in pre-press for several years.
I am proficient with the following RIP software. Onyx, Wasatch, Colorspan RIP, and Caldera.
I am an expert Adobe Photoshop power-user with over 10 years experience.
I also know and use both GretagMacbeth Eye-One and ProfileMaker.
I also have technical hands-on and maintenance experience with the following solvent ink wide format printers.
ColorSpan DisplayMaker 72si, Nur Fresco series, and HP Scitex XL1500.
I plan to contribute to this forum, and hope to learn a few things too.
cheers!
Miller Metal Imaging
Hi All
MMI produce anodized aluminum signage, we are based on the East Coast of Australia and have been operating for some 14 years.
We use a Heidelberg Signaseter to produce photo positives and Rip to this with Torrent v5.5
Looking forward to better understanding the Torrent software, especially reducing waste through better nesting.
Regards,
Jon
MMI
Hi Cory
My name is Mike and I am the owner of Toucan Design, Inc. Great forum! Lots of informative info here. Glad I found it.
The Tenderizer
The Tenderizer
ID
I am the Tenderizer. Before the Univers font was, I am. I made the Film. I made the Plates. I created the PDF Pages and the Imposition Templates they inhabit; I move them here, I put them there. They go as I say, they do as I tell them. I am The Lord of The Files and my name is never spoken, the name which no one knows. I am called The Tenderizer, but that is not my name. I am. I shall always be. Your 36 layer .ai file with transparency is now mine; I shall flatten it as I see fit. To Me, your vitriolic wails and lamentations are merely the sound of one hand clapping.
EGO
**Ring, ring!**
"Tenderizer Press, this is T, how may I help you?"
"Well, hello Ms. Hubris... so you received your hardcopy proof..."
"Yes..I see... one moment, let me pull up the file..."
" Ok, Yes, I see here in our preflight form that we noted all the hairline rules were four color build ...but.. you did not want to change them..."
"Yes, the 'outlines' you're describing are called traps... yes, it's necessary to do that because on press the paper tends to.. yes, you see it stretches in the direction of the grain... no... not wood-grain... no there's nothing wrong with our press, its just.. it's just a physical reality of the printing process..."
"Yes.. we noted the .gif files in the preflight form... that's the result of a low resolution raster graphic... I see... the picture... it's... they're called Pixels... yes... the picture will look different on your monitor than on the proof... because..."
"Yes, I understand that the 'PuffyPals! Plush Toy Fan Club Newsletter' is very important to all its members. Yes, I see that... you certainly did put alot of work into your Publisher file..."
" Yes, Ma'am, I.. I'll be more than happy to have my Supervisor call you..."
"Thank you... OK... have a nice day, Ms. Hubris."
SUPEREGO
I know you want to leave in all the typos that the PITA customer didn't catch. I know you want to re-name that re-saved Photoshop file something vulgar. I know you want to add a subliminal message to the textured background of that guy's mugshot. I know you want to cherry-pick the job rack.
I know you.
Hi, Colorblind.
Did you ever use the Colorblind Color Management software/hardware?
My first real job out of college was a digital print-house, and they were in the process of setting up a color-managed workflow, using Colorblind.
I was as green as could be when it came to prepress, and didn't even know what color management was, but I do know that it was a major project that never worked out for that company.
Hi to everybody...
Hi to everybody...
Hi.. My name is Omar, I work in Sistecopy, this company is in Mexico, Guadalajara.
Whe produce all commercial printing in low and hi demand with equipment Xerox like Docutech and Doculor machines, for the offset whe have a Heidelberg equipment 2 SpeedMaster 74-4P, SpeedMaster 52-4, PrintMaster 74-2P.
I am charge for all prepress department, whe have 2 CTP, 1 Prosseter 74, 1 Cobalt 4, for the process we have:
Rip Navigator 7.2
SignaStation 3.0
Metadimension 5.1
OneFlow 2.0
Efi ColorProof 3.1
PrintReady 3.5
The company buy the Prosetter and the Metadimension, SignaStation and PrintReady few months ago, all used but in good conditions, the only bad is the PrintReady that don't have manuals or instructions, that is the reason for I join to this forum group to learn how its works.
Thanks for let me take a part of this community.
and sorry if my english is not good.. :)
Hi there all. I'm Greg and have been working in the Commercial and Newspaper industry for over 30 years. At the moment I'm the assistant prepress manager in a newspaper prepress department (goss web printing 40,000 papers daily), in Tasmania, Australia, which is gradually changing to become an advertising agency/newspaper production department which is an exciting move. I've seen heaps of changes over the years, but today's technology is the most exciting yet. We are running PCs using XP, just upgrading to CS2 after many years with Quark 4. We use the Cybergraphic system which outputs through Prinergy to Trendsetters at our Print Centre.
Outside of work, I'm married with a 12yo girl and 10yo boy and love playing golf.
Look forward to watching many posts.
Greetings! I'm a former A/V production assistant who got a job at a prepress company because I knew how to use a Mac. That was in 1992. In my thirteen years there I became somewhat of an idiot savant, learning a lot about electronic prepress but never dealing with the folks who actually put the ink on paper. In 2005 I embarked upon a two year vacation from the industry, homeschooling my kids while my wife taught English in China. With some reluctance, I returned to Seattle in 2007 and now work for a small print shop doing Mac work that's ridiculously easy and finding myself a bit stretched as I'm exposed to other areas of the industry. This forum has been very useful as I've been getting my head back into prepress mode. (Ah, the things we do for a paycheck....)
In my spare time I enjoy my wife, two daughters, reading, writing, photography, hiking, getting annoyed with my church and wasting time on the internet.
Hello everyone, my Nom de Plume is " Alois Senefelder" which you should all know was the inventor of Lithography, but seeing he is dead I thought he needed resurrection!! just to instill more knowledge of the " Chemistry/ Fundamentals of Lithography" Myself I am a recently retired Lithographic Printer from the UK. I had the pleasure of serving a 6 year Apprenticeship during the days long before Ctp Plates - when it was the norm of 3/4 hours making Litho plates, these ofcourse were the famous "Deep-Etch Plates" which started with the "Graining then Coating - Exposing then Etching and Lacquer the Image areas, at times I felt more like the " Sorcerer's Apprentice"
Regards Trevor
I work on one of Swedens biggest Labelprinting company.
I started my career as a label printer on UV flexo, offset and letterpress.
After 8 years as a printmaker, I was asked if I wanted to start on PrePress as mac-operator.
Held on to it within 4 years. Now I'm as supervisors under the same title last 1 ½ years.
Esko Artwork: FlexripC
Flexproof
Flexproof for Indigo
Flexproof for Indigo with VDP
Packedge w Powerpack
Shrinksleeve option
Step & repeat
Plato
ArtiosCAD
ArtPro
B1 CTF-Bitbus
B1 CTF-Canbus
DeskPack
PlatePatcher
PlatePrep
Plato
WebCenter
Kaleidoskope
Flexo suite
Grapholas
Other Software:
Adobe pro cs3
Quark 7
HP Indigo Security Printing utility
Equipment: 5 Mac Pro with Parallels Desktop (running Esko in PC mode)
Purup Imagemaker
Epson 7880
X server with X raid
Retrospect backup with lacie biggerdisc
1 CDI Spark XT 4835 optics 25
1 CDI Spark XT 4835 optics 40
Kongsberg XL20
Exposure for flexo, offsett, letterpress and Screen.
FAST
Make also all our screen printing cylinder inhouse,
and soon even our braille printing screens also.
My name is Rob and I joined Print Planet through the advice of an acquaintance. He thought it'd be a good place to get in touch with professionals in the printing industry.
I am in Portland, OR and currently working closely with a commercial printing and packaging company that is looking to bring on board a strong printing manager to oversee their printing department. The machines this company uses specifically are Komori, Planeta and a Maxson sheeter. If anyone out there is interested in learning more about this position or to network in general feel free to respond.
It's a good company and I am just working with them to help surface strong, interested individuals. Thanks for listening!
(503) 612-2048
[email protected]
Hello!
Hello!
Hello my name is Joel aka "LoneStar."
I've been involved in the print industry both as a designer, art director, and in the production end as a prepress specialist since 1981. My family owned a small quick print shop while I was in high school and after attending college I worked for a regional/national advertising agency producing all types of printed materials from newspaper and magazine ads, collateral material, to outdoor poster designs.
I returned to the world of print production working at a service bureau scanning oil mounted chromes on a Crosfield drum scanner and outputting thousands of miles of film using this funny little contraption called a computer and its archaic software. The company I worked for during this time was owned by a large commercial printer and was absorbed as the service bureau industry was phased out. We (three of us) were brought in and replaced 25 plus strippers and other production personnel with computer to film output and digital proofing. A few years later we moved to CTP and another couple of employees were let go. Real popular! All in the name of progress and TURNAROUND.
After a while I was recruited and hired by my current employer, a large university inplant to come in and revamp their prepress operations and manage their graphic design department. Within five years we moved from film based output to CTP.
Our output capabilities include: Heidelberg MO, three Ryobi 2 color presses, and 2 Nuvera digital printer/copiers. We are using a RamPage RIP, DynaStrip Imposition, Fuji (Screen) 4300e CTP, Epson Pro 7800 and 2400 proofing devices. Consumables: Fuji Pro T plates, various Epson papers and inks.
We have two full time designers who have been trained to preflight, RIP and output proofs of their files for our customers, if approved all that has to be done is then impose and output.
Love my family, love my job, and look forward to conversing with others about what we do!
Joel
Hi there!
Hi there!
I've been in Prepress for about 9 years now. I currently work for a magazine publisher who covers most of the pet consumer market. Right now I'm working with Evo ver. 4.0.6.2 and Preps using a vector pdf workflow and ultimately creating 1-bit tiffs.
I ran a print brokerage in NYC for 30+ years. Yes, it's true, I was a printing broker. Even worse than a salesperson :mad:
Client base was "high design" (read finicky pain in the ass prima donnas). The wierd thing is that I really like these folks since they push production to it's limits. Hard to make money. But we won lots of awards.
Anyway, I started a dot.com that crashed in March 2000. Then was print consultant on a dot.com that was purchased by one of the big guys. Then taught print production at Parsons for 7 years. These days I am managing partner of my consulting firm that focuses on developing new products for digital printing.
Hi Everybody,
I'm Mohammed A Al Nejaidi, proprietor of Al Tejarat Est for Digital Systems and Printing Solutions - a company based in Riyadh, Saudi Arabia dealing with Pre-press Solutions. We are 7 year old company engaged in spare parts (used and new) supply, RIP Softwares & Hardware (used and new), Support Services etc. We have well trained in house engineers and support helpdesk to work 24x7 basis.
I'm a Pre-press specialist with 20+ years experience. We supply used parts with 75/90/120/180 days warranty and replacement facility. We have complete spares for all Agfa CTP, CTF and Processors.
We also have a god stock of spares for Scitex Dolev, Cymbolic Sciences, Gretag, Esko etc. etc
We have a good library for service manuals for 3400+ CTF/CTP/CTcP/Web Offset/Sheetfed Offset/Scanners/Other devices. Also we have DATA CABLES, RIP INTERFACE CARDS, SCSI CARDS, PATCH CABLES AND POWER CABLES.
SUPPORT SERVICES AVAILABLE AT MODERATE RATES. PARTS SERVICE AVAILABLE SOON.
Al Tejarat Est.,
Riyadh, K S A
[email protected]
