I have had an EnPress for just over a year. I would not recommend this printer to anybody!
We have been through 4 replacement doors, conveyor parts, exit conveyor parts, and replacement drums (originals damaged).
When I refused to order the extended warranty, (wasn't about to pay for something they couldn't fix under the original 1 year warranty),
they finally sent a replacement printer. This one, though quieter, was no better on feeding.
It works considerably better on #10 envelopes than any other size but we still have to have someone manning the printer to clear jams.
It will jam or fail to feed about 10 times per box of #10 envelopes.
Remit envelopes, you may get 10 to print before it jams. We have to clear jams 40-50 times for remits. About the same ratio for A7's and 6 3/4 regular envelopes. This is with the special $500 A7 fuser installed.
Its actually faster to hand feed one at a time.
Be prepared to add half an hour labor to every box of #10 envelopes you print. Double or triple that for every other size. Add to that the cost of envelopes ruined by the jams.
I will say tech support was very attentive and tried everything for the first year. Its just a very poorly engineered feeding system.
There is no internal registration, so skewing is also a problem. Setting the gate tight enough to prevent skewing causes the conveyor to not work properly.
The feeder system is designed to load with the flap up and envelopes are supposed to feed by shoving new ones underneath the one being fed, creating a tidalwave type
build up behind the feed roller. Even with the special fuser, you have to run slow to get the toner to adhere to the envelope.
You can't polish cheese.
dave
dave
