Hi, I've a small copy shop in Singapore, with a Xerox DC5000 with Creo. We've been pretty happy with it for the past 2 years. Its running along side our DC1250/DC1256 (splash).
Of recent, we've been having problem with some of our orange/red print outs (Flat 1 color Book covers) on 256gsm artcard stock. Single sided prints. (CMYK values of these colors are 0/60/100/0 for orange and 0/100/100/0 for red, and the worst was when it was a 20/100/100/0) Same issue happens on uncoated and thinner stock. The most obvious is for thicker/coated stock.
The top edge and bottom edge of the landscape A3/SRA3 print out (i believe its called outboard and inboard) has very different colors. I cant explain it colormetrically since I don't have a spectro handy, but i could have it scanned and uploaded somewhere if needed. Basically if i printed a strong orange, the top looks like a bright orange (fruit), and bottom part looks like its the same orange (fruit) left to dry for 2-3 days.
Its recreated by using Indesign/Illustrator, fill a whole A3/SRA3 with a single orange/red color. and sending to the DC5000 and print. (200 Dot). cutting off the unprintable areas. I cut two long strips off the top and bottom, around 50mm each, and compare.
I tested the same printouts on the DC1256/1250 and the difference is not that obvious. This is not a banding issue.
We've called up Xerox and they've been adjusting for the past few days. I'm getting varied replies from the technicians from "its like that." to "lets try to replace X part". And its worrying me. They said its the "maximum we can adjust the printer"
Anyone else got this problem ? Any good suggestions ?
(I've tried other colors, including 30-60% CMY greys, blues, purples, yellows, and its not that bad. I understand there will always been variances, but for orange/red its very bad.)
From the CED, it says "Inboard to outboard density - CIN 60% @ C,M ,Y and K; Maximum Desnity difference </=0.16" - What does that mean ?
Update: (Happened after i posted, got word from the xerox engineer) They adjusted it now such that the top and bottom strips are almost the same color, but they are both now lighter then the center part of the print out... LOL.. *sobs* My poor printer is still in pieces, and man there's a ton of fuse inside...
