PricelineNegotiator
If you pay me I will fly to you and show you how to use the machine VERY well.
I'm struggling a bit with reconciling your various comments and posts on here as some of it seems quite contradictory.
You seem to be suggesting that the Versant is no better than the 550 and there was no point upgrading. But you said earlier:
So clearly you couldn't just go back to the 550 - that wasn't doing what you needed it to do.
You've also said about the cost of the Versant being a waste, but you again said that you're paying less for it than you paid for the 550.
Quite honestly, it seems like you've managed the hard part which is to find a niche which you can work in order to get business. However, it really seems like you don't know what you are doing when it comes to basic production printing workflow.
My suggestion to you would be to absorb as much input from the professional printers on here, and figure out (getting paid training if necessary), what the most effective workflow is for your product.
You need to basically forget about how you were doing things on the 550 and start from scratch with the correct way of doing things on your new production machine.
As several people on here have shown today, they can print out and trim down the documents you showed to a high level of accuracy in no time at all, and if they're doing longer runs the registration is probably fine too: when you are complaining about registration it actually sounds like more of an issue with processing the documents in an inconsistent way, rather than the machine holding the registration over repeated prints.
So take a few steps back. Listen to the advice, get training (perhaps from Xerox or your supplier, or even someone off here will probably do a day's paid consultancy for you) and redesign your process from scratch.
You're making this all way too difficult.
Re quality, this is another area where you probably need training to dial the settings in right on your machine. The Versant is capable of higher quality and more importantly with a much greater level of consistency than your old machine.
I say this as someone who has set up an in-house repro recently. I admit with most of the stuff I haven't got a clue what I'm doing, but I recognise my own limits and wouldn't make blanket statements that the equipment is no good when I'm using it the wrong way. I know enough to do what I got the equipment to do; and there are potentially loads of other things I want to expand into but I need to learn and get training to be able to figure it out. None of that is a bad thing, but please just listen to the advice people are giving you, forget about your workflow on the 550, which clearly did not work and was a bodge job, and start from scratch. What you are trying to do is not complicated if you go about it in the right way
This reads as though you were happy with those 10 posters in 3 hours from the 550 ! You must have been recycling reams of paper every day and paying for thousands of clicks you never resold.I could go a few hours on the 550 & get 10 posters with that method...I can go the same time on the V180 & get nothing with an even margin...
With your new rotary trimmer, make sure you're printing crops on the oversized sheet, work clockwise rather than opposite sides so you don't end up cutting your top & bottom crops off early and use the screen printed rulers for your last (long edge) cut.I got the Dahle chopper...& that seems like a whole new can of worms to me.
I think the biggest thing to take away from this is that your process isn’t how anyone else does things. So your doing it “wrong” based on industry standards. You were able to get away with it because the 550 just deleted everything 3mm from the edge. So your image might not have actually been registered correctly. It just looked like it because the 550 couldn’t print any further to the edge. The 180 has different tolerances. That’s why your old process isn’t working now.What I mean is...I could print at 100% & chop down on the 550 if I'd of wanted. I always used the scale to fit method & printed on A3 if I needed an A3 poster etc.
I could go a few hours on the 550 & get 10 posters with that method...I can go the same time on the V180 & get nothing with an even margin using the scale to fit method using SIQA & then tweaking the manual alignment.
I'm paying half the cost per click that I was on the 550...but it seemingly can't do the same method I used on the 550 as it just uses tons of paper for nothing except frustration.
I got the Dahle chopper...& that seems like a whole new can of worms to me. There is a lot to learn & I accept that.
I'm going to get an analyst out for the machine & maybe there are some settings to work on.
If not I'll have to get used to chopping down, but it's an extra step I never had to do before.
I felt I knew much more about what I was doing on the 550 so understand about knowing your limits.
I appreciate everyone's input...and the ability to vent my frustrations to an extent.
As a modern digital production press, there will be 101 things the V180 does better than a large office MFP. It's just you are not making use of those benefits, because you only print a handful of posters.1. The V180 is no better than the 550 if you are not reliant on front-to-back registration.
Sorry, but you're contradicting yourself. It seems from what you've said there is very much a noticeable difference in quality. Put simply, your V180 is calibrated and accurate, whereas the 550 isn't. This is no different to our KM C4080 vs C454. For the work we do, we noticed it in background colours. The V180 output will of course be less forgiving, as it is more faithful to the artwork.2. There is no noticeable difference in print quality. In many cases, I have had to use photoshop to eradicate issues that didn't show on the 550. You might say it's more honest, but not useful for me.
3. I have had to rework all of the artwork we used in photoshop because the V180 colours are darker than the 550.
The plastic guide on those things is just that - a "guide". There is play in them, so you won't get an identical result every time, also it depends how you line it up on the grid. Use the crop marks in conjunction with your own two far more accurate guides (either side of your nose) and the job should be a goodun!4. I'm having to cut down now & it happens to be the case that my rotary trimer is not square (just my luck!),if you put the paper next to the guide & cut, it will be closer to 1 crop mark than the other.
I expect this is only happening after you go at a sheet with the trimmer two or three times, trying to shave half an mm off an existing cut. Line up to your crop marks as above and this problem will go away.5. Print that is cut down can get a frayed edge which then gets thrown away.
This is 100% operator or environment error. You should be having virtually no wastage with a modern digital press. None of the rest of us on here are chucking masses of freshly printed work into recycling (apart from when a customer changes their mind).7. The V180 wastes as much paper as the 550 did, whether it's a pixel out on a black print (time & time again) or some other issue it's like final destination...something will always happen to use the paper up.
You really must revoke this statement as it is just so wrong, on all levels.the V180 is only really any use for a small run, leaflet/flyer printing operation IMO
This is the best thing you've said in your entire post.I totally regret not getting an inkjet.
I have PM'ed you multiple times asking for you to show me your operation so that I can help you facilitate achieving more orders. I am starting to feel that you enjoy banging your head against the wall, and are not interested in hearing from an individual that knows what they are talking about.After a few weeks of using the V180 whilst cutting down from larger sizes & 100% Scaling. Here is my opinion:
6. Printing edge to edge is much harder to handle, now requiring gloves etc.
Due to all of the above, I am barely managing a few orders a day when I was handling 30-40 at peak on the 550 & the V180 is only really any use for a small run, leaflet/flyer printing operation IMO & I totally regret not getting an inkjet.
I get frustrated just reading his posts. It is sad to see someone have a beautiful machine but not be able to use it to achieve their goals. I know for a fact that he can have an incredibly efficient operation as I did some homework on his Etsy business and the items that are listed there are, in my opinion, something I could print thousands of in a single morning without breaking a sweat, as I have done that very thing on our V180P.As a modern digital production press, there will be 101 things the V180 does better than a large office MFP. It's just you are not making use of those benefits, because you only print a handful of posters.
Take a simple example that we do all the time - a run of 200-500 posters with heavy solids, onto 250GSM coated stock. Our production press does that perfectly in a few minutes. Sheet #500 exactly the same as Sheet #1, delivered cool and perfectly flat, no jams. The same job on the MFP would be a fight. It would get there an hour or so later, with poor registration and misfeeds from the bypass tray, some nasty jams in the fuser to burn fingers on, and the output on the delivery tray would be curled and too hot to touch.
You urgently need to find a friendly local digital shop and spend a week in there helping out for free, looking and learning everything they do.
Like me saying "The Gibson Les Paul is a totally shit guitar as I bought one and can't get a decent tune out of it"
Notwithstanding, I've never played guitar!
A half decent inkjet is the right tool for what you are doing (printing posters to put in frames and hang on the wall)
The difference in colour and vibrancy would be remarkable.
As I've eluded to before, the inkjet would also enable you to produce the more profitable A2 and A1 size posters you used to sell, which were showing as 'out of stock' on your Etsy shop last time I looked.
I was thinking about this last night and came to the same conclusion as you.... dust on the input sideIf you're only running single posters now and then I'd bet it's a dust issue you're having causing random spots.
andI have a V180 in my living room.![]()
IIRC, he also said somewhere that he had the "most basic configuration" which is an engine with trays 1&2 underneath, a bypass tray and a catch tray. Maybe wrong, but I'm visualising exposed substrate on a permanently loaded bypass tray in a carpeted living room, with kids, pets, dust... and then wondering why there's spots on the posters...... has to be installed/removed via a window...
I no longer really have the dust issue. Yes, carpeted room but the room is off-limits unless the printer is on. I ran an air purifier 24/7 at one point & maybe that helped but I'm really not seeing the dust /spec issue anymore. I do agree this was probably part of the issue with the 550 as it was in a different room. I've totally changed my opinion on the V180.I was thinking about this last night and came to the same conclusion as you.... dust on the input side
This is the same guy who on another topic, said:
and
2. Install some of that foam on the wall that streamers like to use. That'll help a bit. It's real cheap too.My opinion after a few months more use of the v180 machine....& chopping everything down.
Pro's:
1. Hardly ever any issues with dust, the extraction is much more powerful.
2. I can now print 10 posters in a minute & they'll all be ok to send.
3. It does print in the same position. every time.
4. It has freed up a lot of time for me & I now can do other stuff which was the main goal.
5. I can usually print & cut down 10 posters while only using 13 sheets. I was printing on average 4 posters to get 1 good one using the old "scale to fit" method & being concerned about 3mm margin.
6. I have had to learn to cut down but this is industry standard so it's a pro I guess.
7. Seems very sturdy.
Cons:
1. I had to rework all of the files I use, the colours came out different the v180 shows flaws that you just could not see on the 550. Much of the frustration came from this.
2. Far noisier than a 550 though this isn't an issue to me as it's not on all the time.
3. Probably not the right tool for the job for my uses & I haven't found anything extra to do with it yet due to the time involved in 1.)
I appreciate peoples previous thoughts on my thread during the dark days when I thought I'd made a HUGE mistake.
An exacto blade and a ruler could do this job. I am absolutely baffled by your incompetence. I am sorry to be so blunt, but nothing about this is hard. You ignore everyones advice and then blame everything but yourself.After a few days of "printing all day to get about 3 posters done" kind of issues..I've had to go back to doing things the wrong way ie printing on A3 to get an A3 poster with a small border.
The V180 prints, I measure from the edge to the crop marks & it's fine....then I start using the rotary trimmer & it all goes wrong from there. I have tried to adjust it, it's still not square.
Anyway it got so bad I bought 2 x Dahle 444's & 2 x Dahle 554's (after returning the 556 for the same issue)
I almost bought a big ideal power guillotine but pulled back from it. If I can't get it square on a trimmer who says a big guillotine will fix things.
I just can't get them to cut square! I've measured the paper too.
I do not feel I am designed for the print industry & things like this really knock your confidence.
With the "scale to fit" method on a 550, I was handling 20-30 orders a day....now I struggle to cope with 15 a week using the crop marks & trim method.
I don't understand why people prefer borderless anyway, things get cut off when you frame them usually.
Rant over.
![]() The Video You Really Need To Watch Modern offset press performance comes with several nuances. Chris Travis, Director of Technology at Koenig & Bauer, shares some details. View The Video |
