Blade pitch???
tomatron
Has anyone ever played around with the pitch of the blade on the guillotine cutter? I'm just wondering if the pitch would have any effect on the transfer of dry ink where the blade cuts through a bleed and transfers it to the backside of the sheet?
Thanks in advance,
I have seen just about every configuration you can think of when it comes to people trying to outsmart the Knife Manufacturers...... Absolutely the best recipe to help you is removing the air from your work and maybe reducing clamp pressure. I have personally never really seen anything make a significant difference....
JW
If the ink is transferred to the next page (this is mostly dark blue) you need coating on the sheets. Afterwards cut.
Buntpapier
Sheet Movement
Sheet Movement
Sheet Movement and Knife Angle.
Hello tomatron,
Having spoken to some Bindery Operations colleagues re - this problem, their opinion
is that the sheets are moving during guillotining. They recommend the following course
of actions, see the PDFs, but with two proviso 1) is the Ink Dry, not just surface dry?
2) the correct Knife Angle?
Regards, Alois
  • guillotine # 1272.pdf
  • guillotine # 2273.pdf
  • guillotine # 3274.pdf
@ Alois
Good explanation if it come to clamp pressure and knife angle. For 99.9 % of all situations very use full.
Buntpapier
P.S: Alois Senefleder died February 26. 1834 ???????????
