Red_Right_Arm
I am wondering if anyone else has encountered this problem.
We use a CTP laser to ablate off a black mask. Our exposure unit is a UV light bank. We use a water washout system. And the exposure unit has two heating racks.
We keep our laser drum clean from residue and we make sure not to tape any plates down to anything other than the bare metal of the vacuum drum.
We make sure that we are wrapping the plate around the drum straight.
We make sure that our heater doesn't get so hot that it will warp the backing material of the plate.
Once the plates are made, they are cut and butted up to each other to verify alignment. In less frequent cases, the bearers look like the attached photo. In most other cases, the plates look fine on our light table, but they look like this photo once they are mounted on a cylinder. And it is always the same one side that is crooked.
We've had the laser checked and had test plates analyzed by our provider.
I've run out of solutions to try or things to look for. Can anyone help?
