Have your tech do the G7 calibration (Konica Version not a true G7 not sure why they call it a G7) with the eye one isis and profile the stocks you run the most. After that when you run a job on the stock select that paper under the color density it will make a big improvement on large runs. We have been running under that calibration for about two months over 700k clicks and no color shift. The first set up takes about 4 hours after that the tech just re-specs the machine after a pm
Thanks will try that. What else would you recommend? If i am honest the local guys here are not good at all. Not enough machines under their control and as a result don't know much unless its in the Konica service book. i don't blame the technicians as such as its not their fault they dont have enough installed. Konica are saying "its a limitation of the device" So they are basically saying not interested
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
